malexandertx
Jul 02, 2017Aspirant
GS105v5 / GS108v4 - Operating Temp and MTBF
I'm choosing either a small cluster of four GS105v5 or two GS108v4 to install underneath my house (probably 105). The Netgear docs are inconsistent on GS105/108 operating temp and MTBF. Can I get cla...
- Jul 03, 2017
Hi malexandertx,
Welcome to NETGEAR community!
These specs for two switches:
GS105 – 5 Port Gigabit Ethernet Switch 10/100/1000 Mbps / GS105;
http://www.downloads.netgear.com/files/GDC/GS105/GS105_datasheet_04Sept03.pdf
GS105 -- oper. temp 0-40C
GS105v5 – ProSAFE Plus 5-port Switch / GS105 V5
http://www.downloads.netgear.com/files/GDC/datasheet/en/GS105v5-GS108v4.pdf
GS105v5 -- oper. temp 0-50C
If you buy GS105v5, the oper.temp should be 0-50C.
NETGEAR Employee
ElaineP
Jul 03, 2017NETGEAR Expert
Hi malexandertx,
NETGEAR Employee
- malexandertxJul 03, 2017Aspirant
Thanks. the "version" upgrade to v5 is subtle! And a little surprising that the oper. temp would change between the two, but nice it did.
I do indeed have the GS105v5, and the box it came in lists the "package contents" as a v5 (on side of box). But the spec list on the box still indicates 0-40C. That might be something for the packaging guys to fix.
