BDT907's avatar
BDT907
GS105v5 mounting
I need to mount the GS105v5 to a DIN 3 (35mm) rail at 90 degrees, such that the power adapter will plug in at the "bottom" and the Ethernet cables will plug in at the "top". Any tips for how best to accomplish this?
I have already removed the rubber feet.
I would like to know what screws fit best into the slots on the underside of the switch box.
Thank you for any suggestions.
  • BDT907
    The switch should have wall mount kit included where you can install the switch at an angle where the Eth ports are facing down or up but if you plan on mounting it on a rail you may want to check custom mounts that are 3D printed like this.
    HTH
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    BDT907
    HTH
    • BDT907's avatar
      BDT907
      Thank you. I am pursuing the 3-D printed solution.
ProSupport for Business
