Texv's avatar
Texv
Tutor
Jun 02, 2020
GS105v5 Prosafe Network Switch - Windows 10 pc only 100 mbps connection
Hey everyone,    Yesterday I bought a GS105 network switch so I can split a connection (all CAT6 cables) between two PC's. One in my living room (30 cm cable, ~11 inches from the switch) one in my ...
  • Texv's avatar
    Jun 02, 2020
    I have fixed the problem after making yet another ethernet cable. I'm not sure what is was in the end, but at least it's fixed now!
ProSupport for Business
