kvukmir's avatar
kvukmir
GS105v5 with Google Mesh
Hi
I have seen very similar questions and close answers but cannot get my connections to work.
I have a Xfinity X1 modem - Google Mesh w/ 2 access points - Netgear GS105 setup.
I have the X1 modem in bridge mode allowing the Mesh to be my wifi with very fast speed. I am trying to run Arlo camera base unit and Western Digital MyFi external harddrive from the switch. Neither device can find a network. I have reset, unplugged everything multiple times and even went another round with Google support to no avail. Please help if you can! Thanks!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    kvukmir,
    Welcome to our community! :)
    It seems that you are having issues with your network. May I know if everything is connected to the switch? Have you tried removing the switch in the network just to isolate?
    John
    NETGEAR Community Team
    • kvukmir's avatar
      kvukmir
      Hi John,
      Thanks for your reply. The switch only has my Arlo base station and the WD ext HD plugged in.
      I have tried unplugging the switch and connecting the HD into the google mesh and that did work.
ProSupport for Business
