Dogfax
Nov 16, 2020Aspirant
GS108, BT Home Hub6, FTTP Modem
Good day all, I have a GS108 unmanaged 8 port switch which i have had for a few years sitting in its box which I now require to use to allow me to LAN connect more devices to my BT Home Hub6. I hav...
JohnC_V
Nov 19, 2020NETGEAR Employee Retired
Welcome to our community! :)
This is just a plug and play device. Please double check your cables if there are any loops connected to the switch that makes it not to work with your network. You may also try to isolate the devices in order for us to check if this is already a hardware fault. If it is already faulty, you may open a ticket here and let our support team know the status of your switch.
John
NETGEAR Community Team
- DogfaxNov 25, 2020Aspirant
Thanks John.
In the menatime I got another swithc leant to me for a day and this worked fine so it must be faulty hardware. New switch works ok now.
