grossner
Jan 30, 2019Aspirant
GS108 Switch Uplink Speed Drops from 1000 to 100 Mbps
I have a GS108 that initially negotiates at 1000 Mbps with my ASUS RT-AC68W, but after ~30 min to a few hours drops down to 100 Mbps. I can see this on the router's status screen (vis web interface) ...
- Jan 30, 2019
Hi grossner,
Welcome to the community! :)
If ever the ASUS RT-AC68W router is not yet on the latest firmware version, I suggest you to upgrade its firmware to the latest version then perform a factory reset and reconfigure the settings from scratch. Afterwards, check if the same problem still occurs.
If the same problem still occurs, if ever you have a spare switch, disconnect the GS108 switch from the existing network then connect your spare switch and monitor if the same problem occurs. If the same problem occurs, then you need to ask assistance from Asus regarding the router. Otherwise, if the problem is gone using the spare switch, I suggest you to replace the GS108.
DaneA
NETGEAR Community Team
DaneA
Jan 30, 2019NETGEAR Employee Retired
Hi grossner,
DaneA
grossner
Feb 20, 2019Aspirant
It turns out the switch wad bad, a different switch has not had this issue. I will RMA the old one. Thanks for your help.
- DaneAFeb 26, 2019NETGEAR Employee Retired
Hi grossner,
You're welcome! :)
Since your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
