SAH2016
Oct 09, 2016Aspirant
GS108Ev3 port issues
Prosafe GS108ev3 8 port having issues with two ports underperforming throughput. Six of the ports deliver 100+ Mbps while two ports only reach 20 Mbps. Looking at the prosafe utility shows none of the...
- Oct 23, 2016
Hi SAH2016,
You're welcome! I am glad to know that it helped. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Oct 12, 2016NETGEAR Employee Retired
Hi SAH2016,
Kindly answer the questions below:
a. What LAN ports on the GS108Ev3 that only reaches 20Mbps? (For example: ports 5 and 8)
b. What is the behavior of the LED lights of the LAN ports on the GS108Ev3 that only reaches 20Mbps?
c. What type of ethernet cable are you using on the devices connected to the 2 LAN ports that only reach 20Mbps? Is it a CAT5e or CAT6 ethernet cable?
d. Have you tried changing the ethernet cable on the devices connected to the 2 LAN ports that only reach 20Mbps?
e. What are the devices connected to these 2 LAN ports that only reach 20Mbps? Kindly indicate the brand and model of the device.
f. Have you tried updating the software driver of the LAN card of the devices connected to these 2 LAN ports that only reach 20Mbps?
g. What is the current firmware of the GS108Ev3 switch?
h. Have you tried to factory reset the GS108Ev3 switch?
I look forward to your response.
DaneA
