SAH2016
Oct 09, 2016Aspirant
GS108Ev3 port issues
Prosafe GS108ev3 8 port having issues with two ports underperforming throughput. Six of the ports deliver 100+ Mbps while two ports only reach 20 Mbps. Looking at the prosafe utility shows none of the...
- Oct 23, 2016
Hi SAH2016,
You're welcome! I am glad to know that it helped. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
SAH2016
Oct 22, 2016Aspirant
That did the trick. The speed jumped to 150+ on each of the ports.
While it's not clear why that helped to that degree, thank you for your help in trouble shooting this.
Thanks
DaneA
Oct 23, 2016NETGEAR Employee Retired
Hi SAH2016,
Cheers,
DaneA
