Reimemonster
Feb 17, 2022Follower
GS108LP seems broken
Hi,
It looks a lot like my switch broke. No matter what device I connect, the device does not get an IP address. It did work yesterday, it does not work anymore today.
Example:
Laptop connected to port 8, IP config "auto",
results in "unknown network" and no IP address
Left LED is blinking green, right LED is off (so far I do not use PoE whatsoever).
What can I do?
Thanks
If you reboot the router and replace the cable between the router/switch does it work?
Example:
With just the switch and random devices connected, there won't be neither a DHCP server nor a router providing LAN, NAT, and Internet access.
One might guess that yesterday, the switch had a working link to the router.
