TheManWho
Jan 14, 2020Aspirant
GS108LP switches off on its own randomly
Hi
Has anyone else had the same issue where the switch randomly powers off and back on again? I have IP phones plugged in to it and it happens minimum once a day, cutting off a call in the process!
Any help would be appreciated.
Thanks,
TMW
You're welcome! :) I'm glad to know that a replacement has been sent.
Since your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Since the GS108LP is an unmanaged switch, I suggest having it replaced.
If your GS108LP switch is still within the store warranty period, kindly return it back to store and ask for a replacement. Otherwise, kindly open a chat or online support ticket with NETGEAR Support here at anytime to process an online replacement.
DaneA
- TheManWhoAspirant
Hi,
Thanks for the reply. Ive since raised to the supplier and they have asked me to return it to them and they will now send out a replacement.
Thanks again,
TMW
DaneA
