EttoreC
Mar 22, 2023Aspirant
GS108PEv3 PVID Configuration Missing
I have a NetGear GS108PEv3 switch that I have been using "wide open" for a while. I recently got myself some VLAN capable hardware and wanted to get things setup. I've run into an issue where a go...
- Mar 23, 2023
Gigabit Ethernet Plus Switches User Manual Models GS105Ev2 GS105PE GS108Ev3 GS108PEv3 GS116Ev2 GS305E GS308E JGS516PE JGS524Ev2 JGS524PE p.38.39, "Advanced 802.1Q-based VLANs: Specify a port PVID"
schumaku
Mar 23, 2023Guru - Experienced User
EttoreC
Mar 25, 2023Aspirant
I'm aware the command SHOULD be there, but it isn't. Why? I've updated the firmware from whatever it was (v.2.0.8 maybe?) to the newest (v.2.0.16) and the commands that are shown in the manual are still not there.
- EttoreCMar 25, 2023Aspirant
Oh, turns out you can't just click the "VLAN" tab and go to Advanced. You have to click "VLAN" then click 802.1Q. At that point, everything will still look the same, but the feature I "need" will be there.
thanks!
- schumakuMar 26, 2023Guru - Experienced User
Exactly what the RT*M says. And no, nothing changed recently ...
5. Select VLAN > 802.1Q > Advanced > VLAN Configuration.
The Advanced 802.1Q VLAN Status page displays. The menu on the left displays
more options.
6. Select Port PVID.
You can select Port PVID only if you already enabled the advanced 802.1Q VLAN
option (see Advanced 802.1Q-based VLANs: Create VLANs on page 35)
