girlgeek
Aug 15, 2017Follower
GS108v4 and Broadcast Storm Protection
does anyone know if the switch is set to Broadcast Storm Protection as disabled???
- Aug 15, 2017
Hi girlgeek,
The GS108v4 it's an unmanaged switch and doesn't support broadcast storm protection so it's disabled.
If you need broadcast storm control I recommend our equivalent plus switch that's the GS108E where the broadcast storm control is supported.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
XavierLL
Aug 15, 2017NETGEAR Employee Retired
Hi girlgeek,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
