ahmedt
Apr 17, 2017Aspirant
GS108v4 no connections to device
Issue: There are no connections for the devices if I connect through the switch. Setup attempts: 1. Internet -> Sky Q modem/router1 - GS108 - direct cat5 cable to desktop or Huw bridge O...
- Apr 20, 2017I read one of the other thread. The connection between the switch and the router needs to use cat5e above cable. I am using a new cable which has 6 or more wires and it works.
ahmedt
Apr 18, 2017Aspirant
With regards to your point 4. How can I check there is a valid connection between the switch and the router?
DaneA
Apr 18, 2017NETGEAR Employee Retired
The GS108v4 is an unmanaged switch. It seems that your GS108v4 is faulty. I suggest you to open an online case with NETGEAR Support at anytime. Let them know the status of your GS108v4 switch. Attach a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of your GS108v4 for warranty verification. If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
