ahmedt
Apr 17, 2017Aspirant
GS108v4 no connections to device
Issue: There are no connections for the devices if I connect through the switch. Setup attempts: 1. Internet -> Sky Q modem/router1 - GS108 - direct cat5 cable to desktop or Huw bridge O...
- Apr 20, 2017I read one of the other thread. The connection between the switch and the router needs to use cat5e above cable. I am using a new cable which has 6 or more wires and it works.
ahmedt
Apr 18, 2017Aspirant
Sorry. What gui and there is only a power button on the switch.
ElaineP
Apr 18, 2017NETGEAR Expert
Hi ahmedt,
Theoretically speaking, GS108v4 should work fine in your topo. GS108v4 is an unmanaged switch, so cannot do factory default. You can reboot it or change other switch ports to use and make sure GS108v4 can work normally or not, if not, maybe your GS108v4 is faulty. You can open an online case.
NETGEAR Employee.
