Vlad1948
Mar 28, 2024Follower
GS108v4 switch
An Installation guide to GE108v4 switch reviews LEDs shining status of individual ports.
Mentioned there is which LED (L / R / both) shoul be on in accordanceg to Mbps amount received on the port.
Advice please which LED should be on when 200 Mbps connected to a port.
Should it be either the left LED be solid green, or both LEDs be solid green?
Thanks for your advice.
- microchip8MasterBoth, as the port will run at 1 Gbps since 200 Mbps is more than 100.
As microchip8 says, but what connects at 200 Mbps?
Wherever the idea is coming from. These switches can indicate 1 Gb/s, 100 Mb/s, and 10 Mb/s link rates.
Sure, a 10 Mb/s full duplex link does deal with 20 Mb/s, a full duplex 100 Mb/s link can handle a total of 200 Mb/s adding both directions, or 2 Gb/s in both directions on a GbE link. Very academic...
Here some details from the Installation Guide:
