TheGlue
Mar 07, 2017Aspirant
GS116 v GS316 unmanaged switches - decisions, decisions
I'm trying to find the answer to the GS116 vs GS316 switch differences. I found the following but what does that mean to the home user. a. The GS316 supports 16K MAC address table entries while t...
- Mar 09, 2017
The GS316 has a feature called Energy Efficient Ethernet (IEEE 802.3az) which is not supported in the GS116v2. This feature uses a technology called LPI (Low Power Idle) which is actually a low energy consumption state that can be used during periods where there is no link utilization. It means that during periods of low data activity, less power is consumed.
Also, if ever you have read the GS316 data sheet, under the Energy Efficiency features on page 2 it says that it supports Auto Power Down and Short Cable Detection. The Auto Power Down mode saves energy when port is unused. The Short Cable Detection detects if you are using a short-length ethernet cable.
I believe these Energy Efficiency features (including the IEEE 802.3az) makes up for the Auto green mode feature that is not supported which is for me is good.
DaneA
NETGEAR Community Team
DaneA
Mar 08, 2017NETGEAR Employee Retired
Hi TheGlue,
Welcome to the community! :)
The GS316 switch is categorized for the SOHO (Small Office, Home Office) environment while the GS116v2 is typically for business networks. Since both are unmanaged switches, I believe you could use the GS116v2 in a SOHO environment and vice versa.
Let me share their data sheets below for more information:
Furthermore, you may want to check the reviews from owners of GS316 here. For reviews about GS116v2, check here. Hope these will help you decide what switch to get.
DaneA
DaneA
The Auto green mode is a feature which detects the cable length and adjusts power usage to save energy. This feature basically tells that the power usage will depend on the cable length.
It is by design that the Auto green mode feature was not included on the GS316 switch.
DaneA
- TheGlueMar 08, 2017AspirantSo the 316 is full power to all the lines all the time?
