vinoth_netgear
Sep 23, 2026Follower
Gs116lp powercord
Gsll6lp need power cord
schumaku
Sep 24, 2026Guru - Experienced User
A power cord - or a complete power supply?
For complete power supplies, have an eye on eBay or Amazon. Look out for 54V power supplies, search eg. for
Netgear GS116LP power supply
When I remember right, the GS116LP came with a 90W model, so offering a total of 76W over all ports.
The difference to the GS116PP was just the power supply (and the labels attached), a 200W model, offering a power budget of 183W - the difference between the LP and the PP variant was just the power supply included.
As these as common industry standard 54V power supplies, there might be also 130W models available, so the switch has a power budget of 115W.
Either way: Don't forget to adjust the slider switch on the back according to the power supply!
GS108LP GS108PP GS116LP GS116PP Datasheet
For your reference, the official Netgear designations (afaik no longer officially available on the markets):
EPS90W: 90W External Power Supply, 54V @ 1.66A, 110-240V, 50/60Hz
EPS130W: 130W External Power Supply, 54V @ 2.4A, 110-240V, 50/60Hz
EPS200W: 200W External Power Supply, 54V @ 3.7A, 110-240V, 50/60Hz
