ab6g23
Jul 11, 2023Aspirant
GS208 - Not able to ping devices in the network
Hi everybody, I'm new here and I'm writing because I bought a GS208 some months ago. Right now I'm using it to connect two different computers on the same network. The problem is that I'm not able t...
schumaku
Jul 11, 2023Guru - Experienced User
Do the port LEDs of the connected devices show an active Ethernet link (on) and activity (flashing)?
- ab6g23Jul 12, 2023Aspirant
Yes, they do.
The fact is that I can see the ip address of the other computer from the prompt (with the netgear device in between), but I cannot ping it. I also turned off the firewall protection on both the computers, but it didn't work.
- schumakuJul 12, 2023Guru - Experienced User
Explain on how you can see (or discover) the IP of the other computer on the network.
And tell the community a little bit more about these two computers. LAN IP addresses, subnet masks of both for example.
