Spezzer
Aug 26, 2015Aspirant
GS208 Connectivity into D7000
Hi - just invested in Nighthawk D7000 modem router and wifi is all good. However, I have a problem with the Netgear GS208 network switch. Its plugged in and switched on but isnt connecting anything. ...
- Aug 26, 2015
Sorted - seems to be the ethernet cable.
Isnt there a speciall type called crossover? I think this is what this might be. Looks like its not required.
Does that make sense? Anywho - a regular cable fixed it.
Spezzer
