Shovelsr's avatar
Shovelsr
GS208 with VoIP
Hi,   I use a couple of GS208 (v2) switches on a Nighthawk R6000, in turn connected via the providers hub (bricked to MODEM mode only). Internally, my network is all Gigabit cabled, externally the ...
  • plemans's avatar
    Aug 14, 2022
    schumaku there actually was an R6000. Very limited release and had the exact same specs as the R6100. I couldn't even find anything about it on netgears support site anymore. So not sure if it was rolled into the R6100 support info or what happened there.
    http://en.techinfodepot.shoutwiki.com/wiki/Netgear_R6000
    Shovelsr I'd try it before trying to adjust anything. The R6*** series or routers weren't recommend to use qos settings at speeds 250mbps+. So I'd try it first. If it has issues, then I'd try its QoS.
ProSupport for Business
