Jamio
Nov 03, 2023Follower
GS305 No Green Light from Cat5e connected to router
I'm struggling for a solution to this. I have a GS305 upstairs to provide connections to a few devices I want wired. I have a cat5e ethernet cable running up through the wall. I have confirmed tha...
Nov 03, 2023Guru - Experienced User
bring the switch down by the router and direct connect it with a 6ft cable. I've seen some laptops be less critical of a sketchy connection than switches.
so its worth checking that even if the cable works on a laptop
