HippoUK
Oct 11, 2022Aspirant
GS305p right light green, no light on left, then after a while turns green
Hi all, Netgear gs305p switch, PoE port provides power to a wireless AP - all fine. Then after a period of time the AP drops. The interface left light is off BUT the right light is solid gree...
HippoUK
added pictures to show issue
Marc_V
Oct 11, 2022NETGEAR Employee Retired
Welcome to the Community!
What AP are you using? From the picture it seems the LED is yellow (100M/10M). Have you tried using a different cable? A different port on the switch does the same to the AP? Do other device connected on the switch loses link as well?
- HippoUKOct 12, 2022Aspirant
Thanks for the reply - I realised that the picture I sent was indicating yellow after I sent it, I also realised that I could only attach 1 photo.
In answer to your questions. Other interfaces appear to be fine. The cable has been tested, the AP was moved to a different interface and experienced the same issues, those being after a period of time (hours) simply prevents Ethernet connectivity albeit the POE is still good.
I have replaced the AP and cable - same issues. So, next step is replace the switch and now installing the Managed version to see what happens.
Thanks
