solokifle77's avatar
solokifle77
Unmanaged Switch GS305P user manual missing
Hi there,
I ran into this switch model at one of our sites. It's cleared that it was configured by another tech in the past because it is passing vlan tagged traffic. I went to the download page but I can't find the user manual. Since I don't know what is the ip address of this unmanaged switch configured, perhaps I can try to do a factory reset and start from scratch. I don't even know what would be the default ip, also the person who was next to the switch coudn't even locate the mac address on a label.
Thank you,
  • schumaku's avatar
    schumaku
    Jan 25, 2021
    Not recognizing anything - much more for example with the computer data adapter untaged, the phone configured for a tagged VLAN, and whatever other VLANs it's simply handling untagged and tagged frames accordingly. Needless to say, this might not properly isolate the VLANs.
    Under the line, this isn't Netgear issue 8-)
  • schumaku's avatar
    schumaku
    The mentioned Unmanaged Switch GS305P however is what it says - an unmanaged switch, nothing to configue, no IP address.
    GS305P | Unmanaged Switch | NETGEAR Support Product Data Sheet and Installation Manual shows all there is - permitting this is the effective product we'e facing here.
    The Netgear Switch Discovery Tool helps to find a Netgear switch LAN IP with a computer on the very same subnet - being a Smart Managed Plus or Smar Managed Pro model - obviously not any unmanaged unit.
    • solokifle77's avatar
      solokifle77
      how is that possible that is able to recognize voice vlans then? That location has 3 different vlans, and what's connected to the switch are voip phones that also passes traffic from other vlans for data.
      Thanks
      • schumaku's avatar
        schumaku
ProSupport for Business
