solokifle77
Jan 25, 2021Aspirant
Unmanaged Switch GS305P user manual missing
Hi there, I ran into this switch model at one of our sites. It's cleared that it was configured by another tech in the past because it is passing vlan tagged traffic. I went to the download page but...
- Jan 25, 2021
Not recognizing anything - much more for example with the computer data adapter untaged, the phone configured for a tagged VLAN, and whatever other VLANs it's simply handling untagged and tagged frames accordingly. Needless to say, this might not properly isolate the VLANs.
Under the line, this isn't Netgear issue 8-)
schumaku
Jan 25, 2021Guru - Experienced User
The mentioned Unmanaged Switch GS305P however is what it says - an unmanaged switch, nothing to configue, no IP address.
GS305P | Unmanaged Switch | NETGEAR Support Product Data Sheet and Installation Manual shows all there is - permitting this is the effective product we'e facing here.
The Netgear Switch Discovery Tool helps to find a Netgear switch LAN IP with a computer on the very same subnet - being a Smart Managed Plus or Smar Managed Pro model - obviously not any unmanaged unit.
