Farelz87's avatar
Farelz87
Follower
May 19, 2022
GS305V3 no internet
I bought a switch box and it worked for a couple days. Now it won't give internet to any device plugged into it. All lights are green.
1 Reply
  • plemans's avatar
    what modem do you have?
    What router is the switch connected to?
    The gs305 is a simple unmanaged switch. It doesn't do any traffic management so its more about whats the switch is connected to. Especially if the lights are on on the switch. If the lights are on, its getting a connection.
ProSupport for Business
