DM56
Sep 05, 2021Follower
GS308-3 adding a second ethernet switch FS105 with jumper
Can you use a jumper to stack two switches? Netgear 8 port with 5 port added with jumper cable. Home application, ran out of ports on the GS308. want to add FS105 switch for the additional ports.
schumaku
Sep 06, 2021Guru - Experienced User
If "jumper" means a straight instead of a standard crossed (X) cable the answer is no. Modern switches have a feature called Auto-X.
