boltsnnuts
Oct 25, 2021Aspirant
GS308 Unmanaged Switch Port Issue (8 port)
After troubleshooting, I was able to isolate the issue. It seems like the switch is the issue. Essentially, anything that was wired would not have any connection. So I unplugged (ethernet or powe...
JohnC_V
Oct 29, 2021NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues with the switch. May I know how is everything connected? Is the switch connected directly to the router? This is just a plug-and-play device. We may need to further check your physical connections that make the switch stop working once you connect the 5th device.
John
NETGEAR Community Team
