bobpak
Oct 28, 2020Aspirant
GS308 Unmanaged Switch Port Speed
I have 5 ethernet connections to the subject switch and all attachments are working as expected. However all port lights are green indicating 1Gb capability. Two of the attached devices are not ca...
- Nov 08, 2020
Hi,
Sorry. It's our mistake.
GS308 port LED supports single color only. So, the LED is alwary green when it's on.
The information in IG is correct, but it's wrong in switch front panel.
Also, it's not belong to S350 series.
We have corrected it in October.
schumaku
Oct 28, 2020Guru - Experienced User
bobpak wrote:Any thoughts on why the GS308 indicates all attacments are 1 Gb capable?
It doesn't differentiate between 10MbE/100MbE/GbE - there is only one port LED on each port, just indicating Link (on) and Activity (flashing) according to the Gigabit Ethernet Switch GS308 Installation Guide
- bobpakOct 28, 2020Aspirant
Pls see the attached picture below. It clearly says that the GS308 should differentiate between 1 Gb and 100 Mb.
Bob
- schumakuOct 28, 2020Guru - Experienced User
Can't see your image yet (requires moderation) - however, all three GS308 versions I?m aware of have just one green port LED:
GS308 (v1)GS308v2 (GS308-200xxx)GS308v3 (GS308-300xxx)
The image I sent is a picture of the front of the GS308 with the following language above the 8 ports...
Green=1000M, Yellow=100M/10M, Blink=ACT
The 8 LEDs could include a green and yellow element.
Thoughts?
