bobpak
Oct 28, 2020Aspirant
GS308 Unmanaged Switch Port Speed
I have 5 ethernet connections to the subject switch and all attachments are working as expected. However all port lights are green indicating 1Gb capability. Two of the attached devices are not ca...
- Nov 08, 2020
Hi,
Sorry. It's our mistake.
GS308 port LED supports single color only. So, the LED is alwary green when it's on.
The information in IG is correct, but it's wrong in switch front panel.
Also, it's not belong to S350 series.
We have corrected it in October.
NeedHelpWithNet
Nov 02, 2020Aspirant
Any word on this? I'm having the same problem.
CageyH
Nov 06, 2020Aspirant
I have the same switch, with the same markings, and same LED. It will never flash yellow, as there are no yellow LEDs in the device.
Mine does not maintain my internet connection though, whereas if I install an unmanaged switch from a competitor, I have no issue. This is the second one I have tried. I just hope there won't be a third.
