bobpak
Oct 28, 2020Aspirant
GS308 Unmanaged Switch Port Speed
I have 5 ethernet connections to the subject switch and all attachments are working as expected. However all port lights are green indicating 1Gb capability. Two of the attached devices are not ca...
- Nov 08, 2020
Hi,
Sorry. It's our mistake.
GS308 port LED supports single color only. So, the LED is alwary green when it's on.
The information in IG is correct, but it's wrong in switch front panel.
Also, it's not belong to S350 series.
We have corrected it in October.
bobpak
Nov 08, 2020Aspirant
Pls see the initial posts I made and responses. The current posts have completely drifted away from the issue. Can someone pls respond to the original issue...should I expect this switch to identify 100Mb vs 1Gb connections per the labeling on the front of the panel above
the ethernet ports or has the case been mislabeled?
DanioY
Nov 08, 2020NETGEAR Employee Retired
Hi,
