frankkeane
Oct 28, 2016Follower
GS308 v GS308v2
I have been using a GS308 for years and i have just purchased another one. This model is GS308v2 what is the differance?
- Oct 28, 2016
Hello frankkeane,
Welcome to the community!
There are some changes on the physical and performance part on the switch. I have listed them below:
- GS308 (Width x Depth x Height) - 158 x 102 x 26 mm (Weight) - 0.4Kg
- GS308v3 (Width x Depth x Height) - 158 x 101 x 29 mm (Weight) - 0.48 kg
- MAC Table size - GS308: 4K vs GS308v3 : 8K
- Buffer memory - GS308: 1536 Kbits vs GS308v3 : 128 KB
Let me know if you have more questions.
Thanks,
JohnRo
Oct 31, 2016NETGEAR Employee Retired
Hi frankkeane,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
