Mananan's avatar
Mananan
GS308 Version 3 | How do you block internet to a specific port?
I have two old NAS drives that I now connect to via GS308 switch via cables, and wirelessly to the internet. However, wireless connection is not the strongest or most reliable and so I would like ...
  • JohnC_V's avatar
    JohnC_V
    Oct 18, 2019
    Hi Mananan,
    Welcome to our community! :)
    We cannot disable anything from this switch as this is just a plug and play device or what we call a pass-through switch. If you want it to work only on the local network, then you may need to have at least a Smart Managed Plus Switches on where you can configure and manage the switch by creating a VLAN and assigning the port to a different PVID. That would technically work, but there is also another way by using a Smart Managed Pro Switch and creating an ACL to block the internet.
    If ever your concern is now resolved or addressed, please close the thread by clicking the "Accept as solution".
    John
    NETGEAR Community Team
ProSupport for Business
