lynlin's avatar
lynlin
GS308P PTP LAG
Hi guys, recently I bought a GS308P unmanaged switch for data collecting system. However, it is found that the lag between two devices is larger than another Linksys smart switch. In this case, the d...
  • lynlin's avatar
    Jun 08, 2017
    Hi everyone,
    Here comes the update of this issue.
    I get a solution of using GS305P instead of GS308P. This solution works. It seems that the chipset has some problem in GS308P.
    So, if you need to some works requiring synchronization, GS308P may not be the best choice at present.
    Hope the engineers can solve it in the future product.
ProSupport for Business
