lynlin
May 08, 2017Aspirant
GS308P PTP LAG
Hi guys, recently I bought a GS308P unmanaged switch for data collecting system. However, it is found that the lag between two devices is larger than another Linksys smart switch. In this case, the d...
- Jun 08, 2017
Hi everyone,
Here comes the update of this issue.
I get a solution of using GS305P instead of GS308P. This solution works. It seems that the chipset has some problem in GS308P.
So, if you need to some works requiring synchronization, GS308P may not be the best choice at present.
Hope the engineers can solve it in the future product.
lynlin
Hi Xavier
Thanks for your reply!
A 10.000 ns delay is horrible, I agree, but it did happen. The problem is I tested two switches in the same condition, but GS308P performed so poor.
Saturated Network - can you check if when you are doing the tests there are other source of traffics that are interfering the tests.
-----Nope, only connected two PTP devices and one PC. Only one software was running.
Retransmisions - Could happen that the packet is retransmited due to a longer MTU or a cable or port issue.
-----Maybe it is the case, but I have to test it under the normal condition, so I cannot change.
Mix Environment- Do all the devices connected running at 1Gbps?
-----The limit of my devices is running at 100Mbps.
XavierLL
May 08, 2017NETGEAR Employee Retired
Hi lynlin,
Unfortunately the GS308P it's an unmanaged switch so it doesn't have any troubleshooting capabilities that we can analyse.
However could you run a wireshark with the GS308P and the Linksys and send us the packet capture so we can have a look on this?
Also if you let us know what is your environment ( PTP models, PC model, sw) we can set up a similar environment and test it.
Regards
