lynlin
May 09, 2017Aspirant
GS308P PTP LAG
Hi guys, recently I bought a GS308P unmanaged switch for data collecting system. However, it is found that the lag between two devices is larger than another Linksys smart switch. In this case, the d...
- Jun 08, 2017
Hi everyone,
Here comes the update of this issue.
I get a solution of using GS305P instead of GS308P. This solution works. It seems that the chipset has some problem in GS308P.
So, if you need to some works requiring synchronization, GS308P may not be the best choice at present.
Hope the engineers can solve it in the future product.
XavierLL
May 09, 2017NETGEAR Employee Retired
Hi lynlin,
Unfortunately the GS308P it's an unmanaged switch so it doesn't have any troubleshooting capabilities that we can analyse.
However could you run a wireshark with the GS308P and the Linksys and send us the packet capture so we can have a look on this?
Also if you let us know what is your environment ( PTP models, PC model, sw) we can set up a similar environment and test it.
Regards
lynlin
Hi Xavier,
Thanks for your reply.
In my current situation, I dont have wireshark right now (I am running in company environment, which has limited access).
My environment is using two B&K LAN-XI data acquisition modules (Master and Slave) and one PC Fujitsu LIFEBOOK LH532, and the GS308P POE. The software is pulse labshop. I wonder is there a similar system you can find.
Regards
