alecher
Aug 21, 2022Aspirant
GS308P, Unable to "Request Hardware Support"
I am unable to "Request Hardware Support" for any of my registered products. Once I click on "Support Options", I get a popup with the button for "Request Hardware Support", click on it and nothing ...
schumaku
Aug 21, 2022Guru - Experienced User
When accessing my.netgear.com , select the product from the My Registered Product List by [Product Info] you are on a URL like https://my.netgear.com/product.aspx?sn=4AB1234X12345 where 4AB1234X12345 is the seral number. When following the [Request Hardware Support] one would expect to be guided to https://my.netgear.com/hardwaresupport.aspx?sn=4AB1234X12345 - not a very challenging task for a browser - unless some backend has some temporary issue.
For completeness - "two browsers" is not the world's most helpful information on assistance - let Netgear know which browser, base OS, version, potentially proxy or VPN in the data path.
- alecherAug 21, 2022Aspirant
I was able to get the "Request Hardware Support" form by clicking on the serial number (not an obvious link) next to the picture of my product. The actual button "Support Options" opens the popup, but does NOT populate the URL with the serial number as you pointed out.
Neither Firefox & Chrome worked with the button. The link generated is https://my.netgear.com/products.aspx WITHOUT the serial number.
- DaneAAug 22, 2022NETGEAR Employee Retired
Kindly access the GS308P support page here then click on the Guided Assistance button. You can login to your MyNETGEAR Account or enter the serial number of your GS308P switch then follow the online instructions to process an online replacement.
DaneA
NETGEAR Community Team
