Akindan
Sep 08, 2023Aspirant
GS316 -stopped working
- Sep 08, 2023I have not been able to find a reset button or port on the switch.
microchip8
Sep 08, 2023Master
What stopped working?
Akindan
No signal being provided to any Ethernet ports. Only a couple of lights are on the unit.
AX5 router is producing a WiFi signal, but hard wire connections to switch or switch itself have failed.
- AkindanSep 08, 2023AspirantPower light is on. But most lights at connections are not.
- AkindanSep 08, 2023AspirantI have tried shutting down all units and restarting them in sequence a couple of times, but switch won’t restart.
- microchip8Sep 08, 2023MasterNot much you can do, then. It's an unmanaged switch with no options. Sounds it might be hardware issue. If in warrenty, contact NG. Most ProSAFE switches have lifetime warranty.
