waygar
Jan 30, 2023Initiate
GS316 not connecting at 1000Mbps
I have a brand new GS316 16 port unmanaged switch. It has never shown display status of 2 lights indicating a 1000Mbps connection. All my cables are Cat 6. PC's are configured for 1Gbps but the GS316...
waygar
Yes I have used both a brand new 2 m Cat 6 cable and a Cat6a with the same result.
Jan 31, 2023Guru - Experienced User
the manual says that if both lights are lit its gigabit. But it wouldn't be the first time a manual was wrong. Did you actually test the speeds to see what its connecting at?
