Akindan's avatar
Akindan
GS316 -stopped working
  • I have not been able to find a reset button or port on the switch.
    • Akindan's avatar
      Akindan
      No signal being provided to any Ethernet ports. Only a couple of lights are on the unit.
      AX5 router is producing a WiFi signal, but hard wire connections to switch or switch itself have failed.
      • Akindan's avatar
        Akindan
        Power light is on. But most lights at connections are not.
ProSupport for Business
