jonesadr's avatar
jonesadr
Follower
May 25, 2017
GS316 POE
Hi, I would like to know if it is possible to activat POE on the 316?
  • HI jonesadr,
    We don't have PoE into the GS316 however you can use our GS308P ( 8-port with 4-port PoE) or GS305P ( 5-Port with 4-port PoE) in our 300 series.
    If you want a higher port count switch I would suggest our GS516TP ( 16-port with 8-port PoE) that's part of our smart switch family. So you will also be able to set up VLAN, QoS, and give you PoE control
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
    • XavierLL's avatar
      XavierLL
      NETGEAR Employee Retired
      HI jonesadr,
      Hope it helps!
      Xavier Lleixa
      NETGEAR CBU PLM
ProSupport for Business
