jonesadr
May 25, 2017Follower
GS316 POE
Hi, I would like to know if it is possible to activat POE on the 316?
- May 30, 2017
HI jonesadr,
We don't have PoE into the GS316 however you can use our GS308P ( 8-port with 4-port PoE) or GS305P ( 5-Port with 4-port PoE) in our 300 series.
If you want a higher port count switch I would suggest our GS516TP ( 16-port with 8-port PoE) that's part of our smart switch family. So you will also be able to set up VLAN, QoS, and give you PoE control
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
TheEther
May 26, 2017Guru
According to the data sheet, it doesn't have PoE.
- XavierLLMay 30, 2017NETGEAR Employee Retired
HI jonesadr,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
