Janglor's avatar
Janglor
Follower
Apr 12, 2020
GS316 Setup -- Possible to have Router downstream?
We're remodeling our house and have put in a home run in our new utility room (in the basement of our 2 story house).  Here I have my Spectrum PC15 Cable Modem which then connects to my GS316 switch....
  • DaneA's avatar
    Apr 13, 2020
    Janglor,
    Welcome to the community! :)
    I'm afraid that the only way is to properly set it up.  The proper order of the connection of your network devices should be: SpectrumPC15--R6400--GS316.
    Since you need WiFi coverage in the living room, I suggest you to deploy an Access Point to the proper network setup I mentioned.  For the Access Point, I recommend you either the WAC505 or WAC510.  The proper order of the connection of your network devices would be as shown below:
    To know more about the specifications of the WAC505 / WAC510, kindly check its data sheet here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
