blitz619
Oct 19, 2023Guide
CM1200 Downstream Blinking
I have the same issue with the blinking downstream light only. I have internet, but the downstream light is very annoying and want to avoid anymore disconnects. I got a 2nd internet line installed for work purposes and the technician recommended I replace all the cables in the green box that included my home internet. Ever since he replaced the cables at the junction box my original home internet would cut in and out and it has never cut in and out since moving into this house in 2021. Did the standard unplug for 120 seconds. As of right now its just a constant downstream blinking light. I attached my logs.
- Tech came out and replaced the splitter that splits to my 2nd internet line. he also ended up replacing the coax connector that connects to the splitter. Reinstalled my CM1200...no more downstream blinking lights and no internet drops so far for about 6 hours. Closing this thread.
- FURRYe38Guru - Experienced UserPower levels are a bit too high: https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router Might ask the ISP to put in a attenuator or a 3db splitter. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. - blitz619GuideIs it at all possible that Netgear modem is causing my high power levels? So I called my ISP (Cox) and requested a tech to come out and check the wiring from the box to my house and inform them to install an attenuator or 3db splitter tomorrow. In the mean time I went and installed their Panoramic WiFi Router/Modem to do some testing and so far for about 4 hours, it's consistently staying online with no issues and no downstream blinking lights and I am getting about 880mb download and 40mb upload. I currently have their 1g plan. I guess since its their equipment it has to work, smh. But my end game is to use my own modem because I refuse to pay $5/month to rent theirs. - FURRYe38Guru - Experienced UserNo. Power comes from the ISP side on the coax.
