Cwin3280
Oct 13, 2025Aspirant
GS324 stopped working, wrong port LEDs illuminated
There was a power outage this afternoon. Once the power came back on, my devices could not connect. After checking every component, I realized the GS324 was the point of failure.
At first glance, everything seemed fine: The PWR LED was green and the various ports were lit up.
Upon further inspection, however, I noticed that the LED ports were off, shifted one row to the left.
I tried a simple setup to validate:
1) A direct connection from the server to the laptop worked well.
2) An indirect connection from the server to port 6 and the laptop to port 10 did not work.
The GS324 shows that the PWR and LEDs 4 and 8 are illuminated.
Powering off did not work. The device is about 30 months old.
Any suggestions?
The GS324 comes with three years warranty on most markets, except China.
Head to https://my.netgear.com/ and check the warranty remaining.
- Cwin3280Aspirant
Unfortunately, it does not have a "factory reset" button. It only has a power button and a Kensington lock. There is no button to reset it on the front or back.
Not a switch I own - I googled some images and unfortunately I'm not seeing a reset pinhole either.
Cwin3280 wrote:
Any suggestions?
Did you try a factory reset?
- Cwin3280Aspirant
