far1's avatar
far1
Tutor
Apr 30, 2021
GSS116E - Firmware download file gone?
Hi All,
The firmware file for the GSS116E file doesn't appear to be there.  If I have the correct link it should have been here:
https://www.netgear.com/support/product/GSS116E.aspx#ProSAFE%20Plus%20Configuration%20Utility%20v2.7.8
But there is only Switch discovery software, plus the Prosafe plus configuration utility - which allows you to update the firmware, but only if you have a file - just can't find the file..
Am I missing something?  Thanks for any help
Far
  • The firmware (and mandatory bootloader) updates for various GSS models had been revoked because to many customers had upgrade problems, leading to inop switches. YeZ ?
  • schumaku's avatar
    schumaku
    • far1's avatar
      far1
      Tutor
      Oh.  Thanks for the response -but wish it wasn't that..
      I remember the upgrade years ago being vaguely fiddly in that it was 2 parts, but the instructions were clear and there were no problems.
      It's sad because some users maybe can't be bothered to RT*M - everyone else ends up with an unpatched/upgraded product :-(
      • schumaku's avatar
        schumaku
        Yes, there was a series of update problems around 2017 or 18. These days, people ended with inop products - what is fatal for most usage. It's not just the "not updated" firmware. That was the reason I made some noise.
        Trouble today we have a much higher customer awarenes for vulnerability fixes. Adding difficulty is that the utility is EoL, not reliable to install and/or operate (experienced tech users use different/newer capturing driver used for the NSDP protocol "injection"). More complexity comes for users not operating Windows systems at all.
        (speaking as a user - I'm not Netgear)
ProSupport for Business
