Gartmand
Apr 03, 2018Aspirant
I am in need of a letter of volatility for a JGS516
I need a letter of volalitility for a prosafe 16 port unmanaged switch model JGS516. Thank You, Debbie
- Apr 03, 2018
Hi Gartmand,
Welcome to our community! :)
Here is the latest letter of volatility for JGS516. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Apr 03, 2018NETGEAR Employee Retired
Hi Gartmand,
Gartmand
Apr 04, 2018Aspirant
I'm so sorry. I was informed a letter of volatility is needed for model JGS516NA specifically. Do you have this available?
Thank You,
Debbie
