ghcolley
Mar 28, 2022Tutor
Internet drops on devices connected to router (not switch) after installing GS108v4
Equipment: Router/Modem - Arris SBG7600AC2 (2+ years old, 4 Ethernet ports) Switch - GS108v4 (new) Devices - both Windows 11, connected directly to router The Windows devices have both WIF...
- Mar 28, 2022did you try different cables? Maybe you have a sketchy cable
Mar 28, 2022Guru - Experienced User
the gs108 is a pretty basic unmanaged switch. they usually work or not. It doesn't have any settings to change.
I'd try it like you suggested with the computers connected and the switch but nothing else.
Then add devices in one at time to test stability.
