lewissurewise's avatar
Mar 21, 2017
Is it possible to use 2 switches in parrallel
We already have a GS324 24 port swtich and are looking to buy another to expand to 48, however are not sure if we should use 2 24 port switches in parrellel, or to just but a single 48 port switch wh...
  • DaneA's avatar
    Mar 22, 2017
    Hi lewissurewise,
    Welcome to the community! :)
    Its alright to connect another GS324 switch to your existing GS324 switch.  As far as I know, there is no limit on the number of NETGEAR unmanaged switches that can be daisy chained or be cascaded together.  However, be reminded that the best practice would be about 2-3 switches daisy chained or cascaded.  It is because each switch that you connect adds latency to the network.
    DaneA
    NETGEAR Community Team
ProSupport for Business
