lewissurewise
Mar 21, 2017Follower
Is it possible to use 2 switches in parrallel
We already have a GS324 24 port swtich and are looking to buy another to expand to 48, however are not sure if we should use 2 24 port switches in parrellel, or to just but a single 48 port switch wh...
- Mar 22, 2017
Hi lewissurewise,
Welcome to the community! :)
Its alright to connect another GS324 switch to your existing GS324 switch. As far as I know, there is no limit on the number of NETGEAR unmanaged switches that can be daisy chained or be cascaded together. However, be reminded that the best practice would be about 2-3 switches daisy chained or cascaded. It is because each switch that you connect adds latency to the network.
DaneA
NETGEAR Community Team
DaneA
Mar 22, 2017NETGEAR Employee Retired
Hi lewissurewise,
DaneA
DaneA
Mar 26, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have questions.
Otherwise, if ever your concern has been answered / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
