FRoller
Apr 13, 2021Aspirant
Is the GS105V5 Barrel Power Connector 5.5 x 2.0 MM ?
It's kind of hard to measure the center pin size and the manual doesn't say one word about the size of the barrel power connector. Can anyone here confirm that the size is 5.5 x 2.0 MM?
Thanks in advance!
Frank
Here is the Barrel Plug Diameter below:
Outside Diameter: 5.5mm
Inside Diameter: 2.1mm
Hope it helps. :)
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Hope it helps. :)
DaneA
